VSX-49 or 49TXi? (1 Viewer)
Larry_B
Just can't seem to decide between these two.
I don't see the 'i' as being that big of a deal, but are there any other significant differences between these models that I'm missing?
If it's the 'i' then I think I can live without it.
Thoughts and advice?
Been out of this hobby for a while so this will be my reentry piece.
Thanks.
John Kotches
Go with the i-Link enabled product. It will make your life easier assuming you pick up a DVD player with iLink as well.
Cheers,
greg_t
Go with the I. You'll need to do a search here and also on the AVS forum, but I believe that the "i" version had a couple of other changes besides the i-link. Not feature related stuff but I think more internal components. I would go with a 49TXi before a 56txi.
eathree
