VSX-1014tx Too big!!
Discussion in 'AV Receivers' started by RyanJE, Feb 7, 2005.
  1. RyanJE
    RyanJE Second Unit
    Jan 5, 2005
    438
    So I went and ordered this thing without realizing how big 18.5 inches deep is. What kind of Stands do you guys have this beast in. Im looking for a TV stand thats holds up to 36 inch TV. Any suggestions.
  2. Yung
    Yung Stunt Coordinator
    Jun 12, 2004
    224
    I have the Bell'o AVSC-2103. It holds my 34" widescreen Sony TV which weighs close to 200 lbs.
  3. John S
    John S Producer
    Nov 4, 2003
    5,460
    Yep, while fairly light, these nicer AVR's are large.
    Usually well beyond what most TV stands / cabinates can take. Generally need to step up to real component rack / shelf system once at this level.
  4. RyanJE
    RyanJE Second Unit
    Jan 5, 2005
    438
    Jon I was lookin at those too. Any good suggestions??
    Yung,
    would that fit a 18.5 in (d) avr??
  5. Drew Bethel
    Drew Bethel Screenwriter
    Nov 22, 1999
    1,209
    Mine's sitting atop my Velo subwoofer until I find a larger shelf for it! :b
  6. RyanJE
    RyanJE Second Unit
    Jan 5, 2005
    438
    Thats gotta be great for the internals. All the stands that would fit it are super expensive.
  7. Stephen Hopkins
    Stephen Hopkins HW Reviewer
    Jul 19, 2002
    2,598
    I'm using a Piano Black, Silver, and glass stand from Wal-Mart. It looks much more expensive than it really was ($80). The 1014TX just barely fits although i'm using fairly stiff cables w/ fairly deep connectors (Canare). Here's a picture of the stand while it still had a Pioneer Elite 43TX in it:
    http://www.geocities.com/nehpets4627/equipment_rack.jpg
  8. MikeGee
    MikeGee Second Unit
    Dec 11, 2004
    292
    I'm going to be getting the same receiver but i'm actually going to be building all of my speaker stands and equipment rack. I was looking for a nice rack and found all of them were like 200$ and had like 30$ worth of materials.
    My suggestion is take measurements of what you'd like to see and do it yourself. Pride of building somthing is the best.
  9. RyanJE
    RyanJE Second Unit
    Jan 5, 2005
    438
    Stephen do you know what brand that is???
    Mike I'm in the same boat. I could easily make something better for less than 2. But that 80$ stand seems nice.
  10. brentl
    brentl Cinematographer
    May 7, 1999
    2,921
    Just do search on this site for "flexi rack".
    I built 1 and I swear I can sit on it ..... and I'm 300 pounds.
    My unit is about 20" deep, and about 20" wide.
    Brent
    Sorry no pictures, I don't own a digital camera.
    Brent
  11. Stephen Hopkins
    Jul 19, 2002
    2,598
    Not sure the brand name. Walmart doesn't have it on the website anymore but I still see them in some stores (but not all). They also have a vertical version to go beside RPTVs for the same price.
  12. MikeyWeitz
    MikeyWeitz Supporting Actor
    Feb 10, 2002
    939
    Just measured my cabinet. Luckily, it is about 24" deep, so NO problem for my 1014 this week :)
  13. Chris_Liberti
    Chris_Liberti Stunt Coordinator
    Dec 25, 2003
    53
    The 1014 is nothing, try a H/K AVR-7200 it is over 20" deep and weighs 72 lbs. I do like my 1014, it seems to have no trouble driving my M&K S-125s yet the AVR7200 would keep shutting down
  14. RyanJE
    RyanJE Second Unit
    Jan 5, 2005
    438
  15. Stephen Hopkins
    Jul 19, 2002
    2,598
    That's the one.
  16. Jarett
    Jarett Stunt Coordinator
    Jul 23, 2004
    158
    hey,
    I recently created a flexy rack. It is awesome and was pretty fun to build if you're into that kind of thing. You can see pics on my website.
    Good luck with ur search
    jay
  17. RyanJE
    RyanJE Second Unit
    Jan 5, 2005
    438
    Hey Stephen
    Hows the ventilation on that. The manual suggests an 8 in clearing. Does it get real hot?
    Nice rig BTY! How do you like your swans??
  18. Vader
    Vader Supporting Actor
    Mar 19, 1999
    810
    24
    Derek
    The oak rack I am using is a mere 17" deep, which is insufficient for a 17" deep amp, allowing for breathing space behind it (4" is good). My solution was to get a piece of particle board furniture, cut it to 21" deep and the exact width of the shelf where I wanted to put the amp, effectively extending the shelf. The weight of the amp is still 90% on the oak, and it's weight keeps everything solidly in place. Of course, You could also remove the back of the cabinet (if it has one)........[​IMG]
  19. Carlo Medina
    Carlo Medina Executive Producer
    Oct 31, 1997
    10,451
    652
    When I first put my parents' system together, I came to the same conclusion: holy crap, it's too big for the wooden entertainment center!
    Turns out though that ventilation is poor in that center, and the fact that the TX1014 holds the front door just a crack open really is a blessing! [​IMG]
  20. Stephen Hopkins
    Jul 19, 2002
    2,598
    I only have about 4" clearance at the top but have had no issues due to heat. I've felt the top after extended periods of use (up to 3 hours) and while not cold to the touch it didn't feel hot enough that any damage could be done, definitely not so hot that I wouldn't want to touch it.
