VR-507/Sawm40/JBL n26,24 calibrating help?
Discussion in 'Archived Threads 2001-2004' started by Jeff Sch., Jan 19, 2002.
  1. Jeff Sch.
    Jeff Sch. Stunt Coordinator
    Nov 30, 2001
    116
    I have had everything setup for about a month now and need just a little more help in calibrating the system.
    VR-507
    First off i have the JBL N26's (fronts) set to normal
    N24 - on
    Ncenter- on
    I have the
    FrontR set to + 1db
    FrontL- 0db
    Surround left - +1db
    Surround Right - +2db
    Center - 0db
    Sub - -2db
    On the back of the Sawm-40 sub, the knobs are
    Bass Level - 1/2 way
    Cut off Frequency - 170 hz all the way up
    (is this good settings for the sub or is the Cut off frequecy to high? Also what is LFE? Is that the cut off frequency?)
    Lastley, i usually watch a movie at -26 to -30db (76-70db)
    Is this to high and can i harm my speakers with this volume
    Overall how does my setup numbers look. Please tell me is i need to change things, and if I missed seting something up on the reciever
    Al speakers are using monster cable 16guage Time winded wire. Sub is using monster sub cable and my Toshiba sd-1700 dvd is using a AR coaxial cable. (all digital connections)
  2. Tim Hoover
    Tim Hoover Screenwriter
    May 27, 2001
    1,422
    Those numbers look about right. LFE is the subwoofer channel. Good move turning the crossover all the way up. That way it doesn't interfere with the crossover in the receiver. My only nitpicking is with the sub level on the receiver. Why turn it down when you can leave it at 0 and adjust the level on the sub itself? Again, this is just nitpicking - don't take it too seriously [​IMG]
    I wouldn't think you could damage any equipment at the listening level you like.
  3. Jeff Sch.
    Nov 30, 2001
    116
    anyone else. Wheres sean when i need him
  4. Jason Wolters
    Jason Wolters Stunt Coordinator
    Dec 18, 2001
    227
