Johan Meyer
- Jul 23, 2003
After extensive research on Volume and reciever db levels
I am still unsure regarding the following?
I see on some Recievers the volume is rated from -72b to +18db Giving a total of 90db's
Others rate from 90db's to 0dbs
Are these two the same overall db's or should you avoid going into the positive db range to avoid clipping the signals that could cause speaker damage?
Effectively leaving the first above mentioned reciever with an effective 72db's only?
