Sheldon C
- Dec 27, 2001
Ok, I've read enough here to learn that when using a seperate amp to power a sub (like the samson powering an svs cs sub) you need to turn the volume or "gain" all the way up. Does the same hold true for a sub with it's own amplifier built in? Do you crank the powered sub to "11" and just adjust the volume on the recieiver?
