Volume of Sub
Discussion in 'Archived Threads 2001-2004' started by Adam O, Apr 8, 2002.
  1. Adam O
    Adam O Stunt Coordinator
    Jul 22, 1999
    91
    One quick question, when determining the internal volume of a sub, do you exclude the volume of any bracing, the actual driver and the amp? As well do you exclude the volume of the port and or the air inside the port?
    Thanks Alot
  2. ArmenK
    ArmenK Stunt Coordinator
    Jan 13, 2001
    89
    correct, you subtract the volume of the amp, driver, bracing and port (which includes the air in the port)
  3. Adam O
    Jul 22, 1999
    91
    Thank You!
    I just calculated all the volumes for the amp, driver etc,
    Are these about right for a Dayton 15" DVC with a 6" - 24" port:
    Port: 12L
    Amp: 4L
    Bracing:22L
    Driver: 12L
    BTW excluding all of this the internal volume will be around 280L.
    Adam
  4. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    Driver will be less than 5L. Port is close enough. 4-5L for the amp is fine.
    Bracing I have no idea without knowing more about the box dimensions and what kind of air flow holes you are using.
  5. Adam O
    Jul 22, 1999
    91
    Thanks Dustin,
    I calculated the size of the tube to be 24" diameter and 45" high: this yields 333L or so. I will have the normal top/bottom plugs ( 1 circle each: 24" diameter, 3/4" thick), as well I will be building some bracing about half way up the tube for an internal amp. This is what I mean:
    http://www.imagestation.com/album/?id=4291956893 Look at pictures 8 and 13.
    I dont think that the total bracing will be around 22L, maybe closer to 14L, but you can never have to much space, right??[​IMG]
    Thanks Again
    Adam
