Volume Levels
Discussion in 'Archived Threads 2001-2004' started by Leonard B, Aug 15, 2002.
  1. Leonard B
    Leonard B Stunt Coordinator
    Aug 11, 2002
    99
    I am calibrating my speakers with a test disc (Ultimate DVD-Platinum). I am using 75db as the reference level on the spl meter for my speakers. My question is, what level of volume should I use on my receiver to do the calibration? My receiver has -92db as the quietest volume and -8db as the loudest. Any input would be greatly appreciated.
  2. Greg*go
    Greg*go Supporting Actor
    Jun 14, 2002
    941
    I use whatever volume makes my front speakers play at the reference level, then I adjust surround speakers & sub accordingly.
  3. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Leonard: think of it this way - the people who made your receiver hooked up a 'reference' speaker, put a SPL meter 1 foot in front and cranked it to produce it's max power & something like 120 db of sound. Then they started turning down the volume and made the display show you the volume reduction.
    (This is not what they really did, but this is the model to use).
    In your home, you have different speakers and sit more than 1 foot away. So the display will not really tell you what volume you should be hearing. But...it does a good aproximation.
    Dont get frustrated if you cannot get your SPL meter to show the same numbers as the display.
  4. BrianWoerndle
    BrianWoerndle Supporting Actor
    Feb 19, 2002
    794
    When the front test tone plays, use the master volume to get the SPL meter to read 75 db. Then keep the master volume there. Then use the individual speaker adjustments for the center and rears to get them to 75 db. Once complete, the volume number you are on will be reference for your system in your room.
  5. Leonard B
    Aug 11, 2002
    99
    Thanks for the help![​IMG]
