Josh Varghese
- Apr 8, 2003
So I used to have my AVR 125 mated with just RCA bookshelfs from RadioShack. After calibrating with Avia, I would achieve 75db with the AVRs main volume set to around -20db. While watching movies I would never push it past more than -20db...that was plenty loud enough in this dorm room.
Well recently I upgraded my speakers to JBL N-series all the way around. N38 mains, and NcenterII, and N24s for surround. Now I noticed that I have to put the AVR to aroud -10db to accomplish similar volume levels. Sure enough upon recalibration it showed I only achieved 75db with the main volume set to -10db. However if I switch sources, -10db is waaaaaaay too loud. Unlike before where I could switch between sources without much of a drastic difference on how the two played back.
1) Why would I have to play the AVR louder to get more volume if these speakers are definitely more sensitive that RCA bookshelfs?
2) What do you AVR users out there play your AVR at for movies?
3) What am I missing?
Josh
[email protected]
Josh
[email protected]
