Volume control on the 6000 HDTV receiver
Discussion in 'Archived Threads 2001-2004' started by William Kwa, Feb 23, 2001.
  1. William Kwa
    William Kwa Auditioning
    Oct 16, 2000
    6
    Does anyone know how to adjust the volume output of the HDTV 6000 receiver? I can adjust the regular 2700 but not the 6000 model.
  2. Al H
    Al H Auditioning
    Jan 7, 2001
    4
    My 4700 does not have a level control of the audio output either as my 2700 has (and the volume level can be adjusted with the remote) Appears that if there is a digital audio output on the unit then there is no volume control.
  3. Jonathan Tuck
    Mar 24, 2000
    26
    I have the 6000 and have never found a volume control - esp thru the digital connection - since all the DD programming is somewhat lower in volume than the regular. That's so they can send you the whole range of the DD signal without having to cut it back from being too loud during the best parts...
  4. CRyan
    CRyan Screenwriter
    Feb 9, 1999
    1,239
    All I know is that the HD programming is much quieter than the SD programming. When I switch from HD material to SD, I about blow my speakers.
    C. Ryan
