Volfenhag 15 in sub enclosure, Help please
Discussion in 'Archived Threads 2001-2004' started by Mike Keith, Feb 19, 2003.
  1. Mike Keith
    Mike Keith Second Unit
    Jan 24, 2002
    324
    Anyone heard of this woofer, it's marketed as a car audio driver. A friend of mine went against my suggestion of using a Tempest and went for one of these Volfenhag 15 sub drivers (ZX4715DVX) and since I already told him I'd help with the construction I thought I'd run it by you guy's and see if some one could point me to a easy fast and dirty on-line calculator that can help me find the proper enclosure volume and alignment for this driver. It will be used primarily for HT on the LFE output with a PS Audio amp bridged to mono @ aprox 120 Watts.
    Here are the Parameters
    Re 3.2 per coil
    Fs 29 Hz
    QTS 67
    QES 80
    QMS 3.97
    VAS 130.3 Liters (4.6 ft3)
    SD .0491M
    SPL 90dB 1W/1m
    Xmax 16mm
    I know this don't look good.
    Maybe some one could give me some idea, he already has some 24" Son-tube.
    Thanks for any help, my modeling program is not up and running and with all the OT lately I don't have time to do it the old fashion way.
  2. Pete Mazz
    Pete Mazz Supporting Actor
    May 17, 2000
    761
    Those params don't look right....I hope.
    Pete
  3. Mike Keith
    Jan 24, 2002
    324
    OOps, I'm sure the correct values are;
    QTS .67
    QES .80
    However the web page does not show the Point in front of these values.
    However a different web page shows these values, and they look to be more likely.
    Continuous Peak Power: 500W
    Peak Power: 1200W
    Sensitivity (1W/1m): 91 dB
    Impedance: 4 ohms
    Fs: 30 Hz
    Qts: 0.526
    Vas: 1.98 cu. ft.
    Qes: 0.614
    Qms: 7.698
  4. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    That is a Pyle sub... Pyle makes junk subs under tons of
    different names like Volfenhag (A german concept hah!) and
    Performance Technique and Legacy and.....
    FWIW I am a member of a car forum where a kid has 2 of
    those 15's and a Legacy 15 billion watt amp, he bought it
    all for like $150.00... He says "Man it slams" yep...
    I bet it does!
    Other than the driver is pathetic I dunno what else to tell
    you.. I am sure you can make it work, but you can't make it
    work as good as a Tempest would have or an AV-15 (when they
    are out)
  5. Mike Keith
    Jan 24, 2002
    324
    I guess I'll just throw it in a sealed box of about 4 cubic feet and go from there, I was hoping there was so easy on-line way to just enter the T/S pramaters and get a optimum sealed volume.
  6. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    WinISD?
  7. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
  8. Marv
    Marv Stunt Coordinator
    Feb 21, 2000
    110
  9. Mike Keith
    Jan 24, 2002
    324
    Thanks very much Jack and marv, good sites, they should work just fine for this project.
