Vob/Mpg won't burn onto DVD! Help!
Discussion in 'Computers' started by CraigL, May 27, 2005.
  1. CraigL
    CraigL Screenwriter
    Jan 16, 2000
    1,863
    Hey all,
    I'm making a compilation DVD and for some reason, every program is having a problem with one file. This vob/mpg will play in full on my power DVD and WMP as well as VirtualDub. But when I try and open it with any other program (TMPGENC, videoredo, dvd-lab) which involves editing or preparing for burning. only the first 3 seconds are recognized and the file stops after that. Anyone have any idea why this might be happening and how i can get around it??
  2. Ken Chan
    Ken Chan Producer
    Apr 11, 1999
    3,301
    Is it a VOB or an MPG? Where did it come from? Is it DVD-compliant? Try demuxing and remuxing it with the MPEG Tools in TMPGEnc.
  3. CraigL
    CraigL Screenwriter
    Jan 16, 2000
    1,863
    it can be either...they're interchangeable.
    that's the problem...tmpgenc won't acknowledge that there's more there than 3 seconds. [​IMG]
  4. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,717
    463
    Have you tried using VirtualDub to create a new AVI of the file (use HuffyUV for the compression), making sure it has the right framerate and size/pixels for DVD compliancy?
    Then use the new AVI file and see if TMPGEnc can process it correctly.
