Buzz Foster
- Jan 21, 1999
- Steve
The new system, when I get around to building it, is going to be based on the AMD Windsor dual-core processor. I want to get the most out of it. Obviously, Vista is a good choice for that.
However, some of my hardware is not going to work on Vista, at least for a while. My M-Audio Delta-1010 is a pricey piece of sound hardware that, as yet, has no Vista driver, and I cannot get an answer out of M-Audio as to whether or not there is going to be one.
I plan to run dual video cards and triple monitors, and I know that XP Pro can handle that easily. But the reason I want to do that is so that I can be running multiple apps like Premiere, graphics editing, DVD authoring, video conversion, etc. Dual core helps with that, but I know that software written specifically for that, as Vista is, is going to take the most advantage of it.
So, I want to start a dialog here and hopefully figure out which I should do: stay with XP Pro 32 bit, upgrade to XP Pro 64 bit, or go for Vista and runa dual-boot, if necessary, to support old hardware.
Thoughts?
Thoughts?
