Dan Joy
- Dec 8, 2001
I am waiting for this SVS 25-31PCi and trying to get everything ready that when it is here, I am set to calibrate. I have my Rat Shack SPL meter and avia disc and have calibrated front, center, and rear with spl meter. I have read various threads on small versus large settings.
I have a Sony STRDE-835(I know, but just a matter of time and currency) that I dont know what the crossover is at(I have email sony recently without reply. My Mirage FRx-7 towers are spec'd at 35Hz-22KHz,+/-3db. Ihave an Mc3 center channel and infinity inwalls. I plan on using rca cable from sub out on receiver to line in svs.
My questions are:
1. If I set fronts to small(recommended from threads I have read), and the way that I have sub connected, can the sub crossover be used, and if yes should I use this to mesh sub with towers?
2. If can use sub crossover with above connection, can I use front large to better serve for music listening. On my Sony, I plan on using auto decode to utilise sub because if I use two channel, I get no sub output per manual. I do know that avia is best used for small setup due to integrated lfe with mains.
What would be you first and perferred way to setup my receiver-sub(60HT/40Music).
Mirage and my dealer advised fronts large, rca to sub with sub crossover at 40-50.
Thanks! Dan
My questions are:
Thanks! Dan
