jnbigbootay
- Jan 4, 2025
- Tim
I just purchased the Viewsonic X-1 4K LED projector. My signal originates from a MAC MINI purchase about a year ago. From the computer to an HDMI audio extractor, an HDMI cable, and a fiber optic digital audio into my Sunfire Theatre Grand Processor V, and finally to the projector (25ft cable through the ceiling). Upon initial hook-up the projector would display "looking for signal" and as soon as it found it, would again do the same. I am using a 25ft HDMI cable from the processor to the projector and a little research seemed to indicate I needed a better cable (the original was 10+ yrs old). I replaced all the HDMI cables with newer 4-8 K rated ones. BUT, over a couple hours of viewing time I will still get the "searching for signal" it almost immediately does find it and return to video but is a bit annoying I have to depress the enter button to cancel out an error screen. EVERYTHING the path is now rated for 4k or more except for the processor which was made around 2006 or 2007. The processor has two HDMI inputs and one out but it only supports video (whence the need for the audio extractor) . I there an issue with the projector or is the issue that my processor can't perfectly handle the higher bandwidth OR is it something else? I have about three more weeks I could return the projector. Thanks for any help or consideration.
