Viewing R2 + other Regions on R1 multi Region Players, Question...
Discussion in 'Archived Threads 2001-2004' started by DeathStar1, Jun 13, 2002.
  1. DeathStar1
    DeathStar1 Producer
    Dec 28, 2001
    3,267
    Hey All,
    I'm seriously thinking of importing the Futurama Complete sets. I missed SO many episodes due to Fox pre-emptions and just plain not showing the show during sports season. But will the PAL factor be a problem in viewing these things on a R1 DVD Player? I'll be installing a Code Free program very shortly if not [​IMG]..
    Thanks!
  2. Jeff Kleist
    Dec 4, 1999
    11,267
    unless you're viewing through a PC, PAL will be a problem unless you have an Apex, Daewoo etc (but the conversion will be bad). The Malata and that JVC model have great conversion.
  3. rutger_s
    rutger_s Supporting Actor
    Jul 7, 2000
    878
    Actually Jeff,
    The PAL to NTSC conversion for the Apex, Sampo, and Daewoos work fine if you are viewing 4:3 material on a 4:3 display. If you are trying to view 16:9 material on a 4:3 display, those players do not downconvert the image for proper presentation.
    If you have a 16:9 TV, then this is not really a problem.
  4. Jeff Kleist
    Dec 4, 1999
    11,267
    My Apex vertically squishes the image even on 4:3 material. Instead of removing lines, they just squish it down to fit in 480 lines
  5. rutger_s
    Jul 7, 2000
    878
    Thanks for the information. I thought all Apexs did PAL to NTSC perfectly for 4:3 materials.
  6. DeathStar1
    DeathStar1 Producer
    Dec 28, 2001
    3,267
    >>unless you're viewing through a PC,>>
    Yep, This be the case with this person here [​IMG].
    Pentium 3, 1GHZ; NTSC Monitor/TV Tuner, Creative Labs DVD Player. Now I'm definetly going to look into getting the Futurama set...
  7. Ted Todorov
    Ted Todorov Producer
    Aug 17, 2000
    3,077
    48
    1,610
  8. Jeff Kleist
    Dec 4, 1999
    11,267
    Ted, your video card will take what's on your monitor and output either PAL or NTSC. It's real conversion
  9. Dave F
    Dave F Cinematographer
    May 15, 1999
    2,885
    2
    Jeff,
    What is the JVC model you mentioned? And can it be made multi-region?
    -Dave
  10. Jeff Kleist
    Dec 4, 1999
    11,267
    Yes, you can buy a pre-chipped version of the JVC. Check my Regional DVD FAQ in the Regional DVD area
  11. Joel C
    Joel C Screenwriter
    Oct 23, 1999
    1,633
    Just a note, I have an Apex 3201 and for $59.99 at Circuit City, it plays R2 DVDs well enough for me and my 4:3 27" Toshiba. I know a better player would look better, but it would also cost more.
  12. Dave F
    May 15, 1999
    2,885
    2
    Jeff- I found a Beta FAQ (http://www.hometheaterforum.com/htfo...threadid=54238), but this listing for VCD reads: "2- JVC ??????". Is there another FAQ that I'm missing? Otherwise, any suggestions on stores that I could check? (the beta faq mentioned Snack Electronics, but I could not find a link).
    I'm in the market for a new prog scan player, so if I can find one that plays multi-region & NTSC/PAL, that'd be a heckuva bonus. [​IMG]
    Dave
  13. Jeff Kleist
    Dec 4, 1999
    11,267
    I'm not home right now, I really need to update that thing [​IMG] Check farther down in the thread for links/model #s
