Viewing Distance
Discussion in 'Archived Threads 2001-2004' started by Chris Lehner, Oct 19, 2002.
  1. Chris Lehner
    Chris Lehner Agent
    Oct 17, 2002
    43
    I'm new here, so I apologize if this is discussed to death. I'm wondering what size set would work best in my room. I've pretty much dialed-in on a Mits 55411, but I mentioned to the salesguy that I was looking at about 9' viewing distance and he questioned whether a 55" set would be too big. Now, my room is 18' in length; so I take the approx. 3' from the forward wall the set will eat up and my proposed seating position and that brings me to about 9'. He suggested maybe a 48" and that's not a bad size set but I don't want to step down to a 311 (no quad-feild focus) and I don't want to pay for a 511 when I don't really need a built-in tuner right now. If I needed to, I could get 14'. What's really ideal on this 55" set?
    CDL
  2. Justin Gates
    Justin Gates Agent
    Feb 26, 2001
    47
    55" too big at 9'? nah, I dont think so. I have a 51" and I sit 7.5' from it. Initially I thought it would be a tad too big but now I really wish I went for the 57"!
    Its all a matter of personal preference really. Plus remember that once you get used to the TV it will appear to "shrink". The 51" used to seem so mammoth as I upgraded from a 32", but now that I'm used to it, the size feels "normal".
    Just my 2 cents.
  3. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    It is not too big. At 55", the absolute closest I would sit is 6ft away.
  4. Craig
    Craig Second Unit
    Oct 20, 1999
    467
    Since you have the option of moving up to 14' away there's not any risk, go ahead and get the 55". I'm about 10.5', eyeball to screen, from my 56" widescreen and the picture is fine.
  5. Gabriel_Lam
    Gabriel_Lam Screenwriter
    Mar 7, 2002
    1,402
    Just plug it in yourself:
    THX and SMPTE viewing distance calculator
    According to THX, for a 16:9 format 55" diagonal screen, you should be no more than 6.3' away, optimally, or 8.8' away at the absolute max. [​IMG]
    Of course, standards mean very little compared with your own comfort levels and preferences.
