View Sonic PJ-860 or Hitachi CP-S225W? (1 Viewer)
Adam_Garris
I'm looking into getting one or the other off EBAY. Anyone who knows which is the better projector, the input would be much appreciated.
Gabriel_Lam
What do you plan to use the projector for?
They're both 800x600 native projectors.
The Viewsonic is actually a higher level model (It's really the Hitachi CP-S860W). It has a slightly higher on/off contrast at 250:1 compared to 200:1. It has 2000 ANSI lumens compared to 1000. The specs may vary a bit according to how they're measured.
There are definitely better choices for home theater, but if you can get them inexpensive enough, they may be worth it.
vertigofilmfanman
