Joseph S
- Dec 23, 1999
Finally took the plunge after waiting for a Blu-ray enabled 8-core monster... I'm just going with the Dual 2.66 and will upgrade later this fall if inclined with the money I would have wasted on the 8 core upgrade.
Any input on VideoRedo Plus running in Parallels vs BootCamp in Xp vs Vista. I'm planning on just getting Vista, but may consider XP if it is going to save a major glitch. Prior versions of VideoRedo had audio sync issues, but I haven't used it for about 8 months. As such, I have a ton of recordings from the EyeTV 500 to edit and would prefer not to check them all aside from commercial break cuts with occasional audio blips.
