VIdeo switching question
Discussion in 'Beginners, General Questions' started by EricTut, Oct 7, 2003.
  1. EricTut
    EricTut Extra
    Sep 26, 2003
    24
    I have the Onkyo TR600.
    My monitor output is Svideo. Chouldnt I be able to see things that run on composite video? (The cheapy yellow cable thing) I know component and svideo cannot be intermixed. But composite?
    This is driving me nuts. I tried plugging in the output from my digital camera, simple device, to the video 4 input on the front of the reciever. No joy. Argh!
    TIA guys!
    EricT
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    I'm afraid not. Most receivers dont convert one type of video to another.
    Each of the 3 video signals (Composite, SVideo, Component) can only be seen on outputs of the same type.
    For the old family VCR, there is a $20 converter from Radio Shack that converts Composite to SVideo. This way your receiver can see all sources as SVideo which simplifies things.
    Warning: the $20 unit is just a cheap filter. I wouldnt use it for anything you care about (like feeding a camcorder signal into recorder). But it's fine for non-serious sources.
  3. EricTut
    EricTut Extra
    Sep 26, 2003
    24
    Aww man! Thats kinda what I thought. I think I figured out what to do when I have a home theater issue.. throw cash at it. Seems to be one of those hobbies, heh.
    Thanks for the info.
    Eric
  4. Rick_Brown
    Rick_Brown Second Unit
    Oct 25, 2001
    449
    Bob, I think you are incorrect. Onkyo receivers do convert video formats, as far as I understand. What EricTut needs to do is not only connect the yellow video jack but also at least one audio jack (even for a digital camera). Onkyo won't display the video unless an audio jack is also connected.
    Try it, EricTut, and let us know what happens!
  5. Bob McElfresh
    May 22, 1999
    5,182
    Rick could be right, but only for some models.
    For example: the high-end Dennon 5700 receiver will up-convert all video feeds so that they are visible on the one component output. But you pay ~$2,500 for the unit.
    There was also a Pioneer receiver (now discontinued) that would convert all composite video to SVideo.
    But these are the exceptions rather than the rule.
