Scott Reiss
- May 30, 2002
Am I right that you can't have a mix of different cables and still video-switch? What I mean is, I can't have the digital cable box and the DVD connect to my receiver with an S-video cable, and the VCR connect with a composite cable, and then have the monitor out on the receiver to the TV as S-video, and then be able to see the VCR source on the screen, right? Because it's effectively composite in to S-video out.
I really want to run S-video from all sources to the receiver and then S-video to the TV, but the VCR only outputs composite, and I really don't want to upgrade it unless it's necessary. So I'm wondering what my options are... I also don't really want to connect the VCR direct to the TV and then have to switch the TV set everytime I go to video. I'm really hoping to get to the point where all sources go to the receiver and then let it do the work, and have the TV be a true slave.
Would the idea be to have something like a composite-to-S-Video adapter, so that the video signal into the receiver 'looks' like an S-video input? Is there such a thing?
Thanks.... Scott in CT
