video quality
Discussion in 'Archived Threads 2001-2004' started by Nathan Cook, Dec 16, 2002.
  1. Nathan Cook
    Nathan Cook Agent
    Apr 10, 2002
    41
    Is there a noticeable difference in video quality between rca, s video, and component cable connections?
  2. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
  3. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Between composite (RCA) and S-vid, there is a noticable difference. Between S-vid and component, the difference is not the same, but there definitely is a difference. I noticed little or no improvement in image, but definitely improved color with component.
  4. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    2
    To add to the comments above: A lot depends on the source and the form in which it stores video information. Sources that store the color (chroma) and B&W (luminescence) separately -- notably DVD and S-VHS -- will benefit the most from S-video and component connections. Sources that store these separate elements in a combined form, such as LD or VHS, may show little or no benefit from S-video over composite (and component probably isn't even an option).
    M.
  5. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Home Theater magazine did a comparision of all 3 connections types from a DVD player to a "reference" 50" RPTV. They came to the following conclusions:
    Composite (single RCA cable): baseline
    SVideo: 20% better than Composite
    Component (3 RCA cables): 25% better than Composite
    They also noted that the difference was less for smaller sized displays, and greater for larger screens.
    On another note: one of our administrators here was using a SVideo connection for his bedroom 19" TV. For grins, he tried a Component video cable and was shocked at how much difference he saw. So he recommends Component cables even for smaller sized sets.
    Hope this helps.
  6. Greg Kolinski
    Greg Kolinski Second Unit
    Oct 13, 2002
    331
    But then throw in the cable box or sat reciever,Some people have noticed that due to the TV having a better comb filter than the cable, or sat box ,composite looks as good as s-video.I have tried it on mine and really cant tell any difference,[​IMG] I guess this theory may have some truth to it?
    opinions????
  7. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
  8. Alf S
    Alf S Cinematographer
    Apr 23, 2000
    2,973
    508
    4,110
    Alfer
  9. Nathan Cook
    Nathan Cook Agent
    Apr 10, 2002
    41
    thanks all
  10. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Note that in each case, to really see the difference, particularly with component, you must RECALIBRATE. If you hook up two different cables with the same settings on the display, it will looks basically the same.
