video install trouble
Discussion in 'Archived Threads 2001-2004' started by Christopher R., Nov 24, 2002.
  1. Christopher R.
    Christopher R. Auditioning
    Apr 5, 2002
    9
    Does anyone know an easy and preferably cheap way to convert a composite video signal to component level?
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
  3. Scott_AH
    Scott_AH Stunt Coordinator
    Sep 26, 2002
    111
    Didn't he say "cheap" when he asked?
    Scott
  4. Bob McElfresh
    May 22, 1999
    5,182
    Yes, he said 'cheap' and .. this IS cheap.
    Look, the most expensive part of your television is called the 'comb filter'. It's job is to convert Composite to SVideo. Another circuit converts this to Component.
    Televisions are judged by how good their comb filters are. These circuits are expensive, needing high-quality components and laboratory-bench equipment to adjust.
    You can get outboard converters. Farajuda makes a nice one for about $12,000. There is some professional gear available from MarkerTek for about $3,000.
    It IScan units for $600-$800 ARE cheap by comparision.
  5. dougW
    dougW Stunt Coordinator
    Aug 14, 2000
    241
    Why would you even want to convert composite to component? That is my first question. [​IMG] Just so you only go to TV with 1 set of component cables for your VCR?
    Lex
  6. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    Note: the iScan unit (any version) outputs progressive (480p) component video and you typically need an HDTV ready TV set to make use of that. (You can also use a computer monitor) I don't yet know of any outboard device that converts composite or S-video into regular (480i interlaced) component video.
    Video hints:
  7. Bob McElfresh
    May 22, 1999
    5,182
