Brian Dobbs
Hi all. I recently bought a Dazzle DVC 80 analog video input device and am having sync problems. I started digitizing some video using a DivX High motion compression codec. Within a few minutes, the video and audio started getting out of sync. Is there another compression codec I should use instead? Which will give me the best results? Are there any other suggestions you can give me? thanks a lot for your help.
