video distribution amplifier
Discussion in 'Archived Threads 2001-2004' started by Grant B, Jan 10, 2002.
  1. Grant B
    Grant B Producer
    Mar 29, 2000
    3,210
    Bought by mistake (Does not play well with Quad shielded RG6 U!)
    Retails ~$ 700 new
    Sell $300 +shipping
    specs listed below
    Grant
    ( try this email address friday to monday thanks!
    [email protected])
    The VIDEOTEK VDA-16WB is an extremely wide band, low distortion video
    distribution amplifier designed to meet the needs of fast rise time graphics
    signal distribution in either component or composite formats. It is provided
    with both gain and equalization controls to help minimize the negative
    effects of long cable lengths on signal quality. A minimum of internal
    adjustments assures low drift of critical bandwidth and distortion
    parameters with time.
    Features:
    40 MHz video bandwidth
    One looping video input
    Six isolated video output
    Front panel output level adjustment
    Wide band cable equalization front panel adjustment (1000 ft. Belden 8281)
    Front panel input/output test points
    Front panel LED power indicator
    BNC input/output connectors
    Rack mountable using Videotek DA tray option DAT-1
    Specifications:
    Input Impedance: 75 ohms, looping
    Maximum Input Level: 2V p-p
    Input Return Loss: 40dB minimum, DC -10 MHz
    Output Impedance: 75 ohms, source terminated
    Output DC Component: < 100mV DC
    Maximum Output Level: 2.0V p-p
    Gain: Continuously adjustable to +/- 6dB
    Frequency Response: +/-0.25dB, DC -20 MHz; +/-0.5dB, 20-40 MHz at output of
    DA using cable lengths of less than 10 feet of RG59/U, at and below unity
    gain.
    Dimensions:
    Height: 1.7"(4.32cm)
    Width: 5.25"(13.34cm)
    Depth: 9.9: (25.15cm)
    Weight: 2.75 lbs. (1.25kg)
  2. Grant B
    Grant B Producer
    Mar 29, 2000
    3,210
    Trade possible or best offer
