Video Connectors... which to use?
Discussion in 'Beginners, General Questions' started by NolanJ, May 3, 2004.
  1. NolanJ
    NolanJ Second Unit
    May 1, 2004
    451
    2
    Is a DVI cable preferred over component cables when connecting an HDTV to a cable box?
  2. Rex Overbey
    Rex Overbey Auditioning
    Apr 27, 2004
    7
    DVI is the preferred video output since it is digital.
  3. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    Nitpicking, but DVI is not preferred "just because it is digital." It can provide higher quality resolutions cleaner, and that it is digital can provide a benefit, which can be extremely significant with digital fixed pixel displays; but that it is digital in and of itself does not automatically make it better.
  4. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    i finally got around to doing some dvi vs. component comparison.
    the quality via the dvi was better, but only slightly so. if dvi was a 10, component was a 9.
    the dvi connection gave a slightly sharper and brighter picture. it wasn't a whole lot, but it was definitely there. so i say if you can run dvi, go for it.
  5. ChrisWiggles
    Aug 19, 2002
    4,791
    Ted: what are you using as your display? DVI will lead to the most significant benefits with digital displays as mentioned. With a CRT, benefits may be quite minimal.
  6. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    good point chris. i should have mentioned what gear i'm using. i have a mits rptv.
    however, at bb, we have the same player as mine (samsung 931) hooked up to the samsung 50" dlp via dvi. i gotta admit the picture didn't really blow me away. but the gear wasn't calibrated, etc.
