Video CD question
Discussion in 'Archived Threads 2001-2004' started by RobertCharlotte, Mar 27, 2002.
  1. RobertCharlotte
    RobertCharlotte Supporting Actor
    Feb 21, 2002
    660
    So how come my DVD player which can play CDs can't play VCDs but my piece of crap eMachines PC can? Is this really a licensing issue? Admittedly, I have a budget DVD player (Toshiba SD1700), but I've seen $99 players that would play VCDs.
  2. Ash Williams
    Ash Williams Second Unit
    Oct 16, 2000
    256
    I don't really know the technical aspescts of why a VCD won't play in your DVD player, but I do know that a lot of older players won't play them. It's not a licensing issue since VCDs contain no copy protection. I used to have a cheap RCA player that I bought in 99' and it wouldn't play them. Recently I bought a JVC DVD player and it has played every disc I have put into it. Check out VCDHelp.com, they have a lot of info on VCD and may have the answers your looking for.
  3. Marc Rochkind
    Marc Rochkind Second Unit
    Aug 26, 2000
    381
    I don't know about this player, but there are players than can play VCDs but not CD-Rs or CD-RWs. So, it you had a commercially-pressed VCD (almost unheard of in the US, but very common in Asia), it would play. A VCD you make yourself would not play.
    This is exactly the case with my JVC XV-D723GD player.
  4. RobertCharlotte
    Feb 21, 2002
    660
    Wow, I had forgotten I asked this question. :b
    I have some discs that are, to the best of my knowledge, "commercially-pressed." They are of the, um, over-18 persuasion and are labeled "Compact Disc Digital Video."
    Does that not make them VCDs, or is there some other designation for this type of disc?
  5. Marc Rochkind
    Aug 26, 2000
    381
    Yes, indeed you have a pressed VCD. Alas, not all DVD players play VCDs. VCDs are encoded with MPEG-1, and the electronics in most DVD players (DVDs are MPEG-2) can also handle MPEG-1, but that's not strictly speaking a requirement, so it's not always included. Or, it could be a simple matter of the logic to recognize the disc never being programmed in.
  6. Jeff Kleist
    Dec 4, 1999
    11,267
    Basically many of the old decks did not recognize the format, even though the hardware was capable of playing them
    All players since 2000 that I've seen recognize VCD's data structure
  7. Brad_V
    Brad_V Second Unit
    Mar 8, 2002
    356
    And nowadays it's good to look for one that plays SUPER Video CDs. I guess for SVCD it *is* a licensing thing. Your E-machine will play them, but only with PowerDVD or similar software.
  8. Leon Liew
    Leon Liew Stunt Coordinator
    Oct 23, 2001
    234
    My Pioneer 525 plays VCDs without problems. Even my first
    generation Philips DVD player(only DD at that time) played
    without glitches.
    As Marc mentioned it is indeed very common over here,in
    fact it's a craze mainly due to the price difference between
    DVD & VCD.
  9. YANG
    YANG Second Unit
    Feb 10, 1999
    471
    2
    When a DVD player is hacked to play multi-region,some programs in the firware will disable certain features on some players...such as VCD playback.This is very common.Go to www.dvd.reviwer.co.uk for more details on this...
