Video Card recommendations
Discussion in 'Computers' started by MarcUR, Nov 26, 2004.
  1. MarcUR
    MarcUR Extra
    Dec 9, 2003
    18
    I'm in the process of upgrading a computer to use it for home theater and was looking for video card advice. I'm going to add the m audio 2496 for audio to my receiver and I planned on getting a cheap video card with a s-video out just so i could set playlists. After thinking about it, I figured i should put a little more money into it so I can view digital pictures as well (won't be do gaming or dvds through the computer). I have a 32" Sony Wega flat screen non HD-tv. I have two requirements for the card, it has to be PCI, and I'd like it to have both a composite and s-video out so i can use it for all my tv's. I'm looking to spend $50-75. My other option is to get a card with just an s-video out and get a conversion cable, but was a little skeptical about that. Any recommendations would be appreciated.
  2. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
  3. MarcUR
    MarcUR Extra
    Dec 9, 2003
    18
    because i only have a pci slot available, no agp. Doesn't that card only have s-video out, or am I missing something.
  4. Joe_H
    Joe_H Screenwriter
    Jun 17, 2001
    1,753
    8
    I believe that ATI makes some PCI cards that might have S-Video and Composite video but i'm not 100% sure on that. Your choices will be very limited though if you need PCI.
  5. Chris
    Chris Lead Actor
    Jul 4, 1997
    6,788
  6. Kris McLaughlin
    Kris McLaughlin Stunt Coordinator
    Jun 5, 2000
    235
    S-video to composite adapters are easy to find at Radio Shack or places like that. I haven't seem many cards that have an actual composite out (without a breakout box).
  7. Greg Thomas
    Greg Thomas Second Unit
    May 3, 1999
    438
  8. MarcUR
    MarcUR Extra
    Dec 9, 2003
    18
    its a refurbed dell dimension 3000, no AGP, just 3 PCI slots. I tried the NVIDEA FX 5200 with my main dell system (4600) and the picture is pretty bad, unacceptable in terms of what i would like to do. In terms of audio, i set up the SB Audigy 2 NX and sent a digital signal to my arcam avr 200 without any problems. Actually exceed my expectations, now i just need decent video.
  9. Chris
    Chris Lead Actor
    Jul 4, 1997
    6,788
    Yep, because of the onboard video, no AGP.
    For TV Output, you may honestly be better off going with an ATI 9200 PCI card, as their TV Out drivers are more mature. And either way, you probably want a copy of Powerstrip.
  10. Greg Thomas
    May 3, 1999
    438
  11. Eric Samonte
    Eric Samonte Screenwriter
    Mar 31, 1999
    1,318
    I'm also getting one for Xmas, preferably one that would run HL2 decently..at around $150? I have a P4B266 Asus MB, P4 1.8, 512 RAM DDR and a GeForce Ti200 64 MB. I guess I'm stuck at Agp 4X for now.
  12. MikeH1
    MikeH1 Screenwriter
    Oct 25, 2000
    1,492
    edited post, I think Eric meant he's already got a card lined up.
