video card question
Discussion in 'Computers' started by Anthony Moore, Mar 31, 2004.
  1. Anthony Moore
    Anthony Moore Supporting Actor
    Jul 12, 2001
    707
    I have an older Vid Card. An NVIDIA Geforce2 Ultra. Besides the spot that i connect my monitor to is another port. It looks like 24 square holes (3 rows of 8). WHat is this? Is it another sort of video out?
  2. brentl
    brentl Cinematographer
    May 7, 1999
    2,921
    DVI?
  3. Gordon Moore
    Gordon Moore Second Unit
    Nov 1, 2000
    340
    DVI on a Geforce2 is unlikely but who knows?
    Is this a NVIDIA reference card or another manufacturer?
    ASUS,
    Leadtek,
    Hercules,
    MSI,
    etc...
    you can use this program to find out make and model...
    AIDA32
  4. Anthony Moore
    Jul 12, 2001
    707
    i got the card straight from dell..i believe its stright-up NVIDIA. can someone direct me to a picture of a dvi port? ill be able to tell by looking at it..
  5. Gordon Moore
    Nov 1, 2000
    340
  6. Anthony Moore
    Jul 12, 2001
    707
    it ALMOST looks like that...but it doesnt have those 4 squares to the side..it has like 3 "slits" instead.
  7. Anthony Moore
    Jul 12, 2001
    707
    i used that aida program and it seems i do have a Geforce2 Ultra from Nvidia...anyone know what that port would be?
    thanks
  8. Gordon Moore
    Nov 1, 2000
    340
    It really sounds like it's DVI...the indicator would be the white port...
    I stand corrected, lots of GeForce2 Ultra cards have DVI...
    for example:
    http://www.digit-life.com/articles/g...gf2u-front.jpg
    Do you have a HDTV or LCD monitor you can try out the connector on. Bets are, it's DVI.
  9. Anthony Moore
    Jul 12, 2001
    707
    thanks,..but what about the 4 holes to the side of the 24? i dont have those..is that ok? can it still be a DVI port?
    Another question: can i convert DVI to RCA or s-video?
  10. Ken Chan
    Ken Chan Producer
    Apr 11, 1999
    3,301
    Without the four holes, it's DVI-D instead of DVI-I: [​IMG]. D is digital only, while I has both analog and digital.
  11. Anthony Moore
    Jul 12, 2001
    707
    is there a dvi-d to rca cable? or dvi-d to s-video?
    thanks
  12. Anthony Moore
    Jul 12, 2001
    707
    anyone ever heard of something like this?
  13. Ken Chan
    Ken Chan Producer
    Apr 11, 1999
    3,301
    There are no simple converter cables. The signals are quite different. DVI can carry a much more detailed picture.
