Video calibration with a twist...
Discussion in 'Archived Threads 2001-2004' started by Mike___Walker, Feb 7, 2002.
  1. Mike___Walker
    Jan 12, 2002
    29
    Here's a question which may be a new one since I can't seem to find the answer anywhere. On my Sony, there are three different Video Modes: Vivid, Standard & Movie. If I used the Avia disk to set the Movie mode, will the settings stay if I switch to Standard mode? [​IMG] My reason is I would like to set two different modes, one for day & one for night viewing. Will it work or will I have to keep changing settings? TIA if I don't get back to the thread soon...
  2. Adam Barratt
    Adam Barratt Cinematographer
    Oct 16, 1998
    2,343
    Adam
    On my last Sony, changing any of the picture modes erased any custom setting. I had to stick with the calibrated settings at all times and recalibrate every time someone changed the picture mode (which was a lot).
    Does the TV have a custom picture memory option? Depending on your level of technical experience, another option could be to find the TV's service code and re-set one of the picture modes to the calibrated levels.
    Adam
  3. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    on my sony i keep it on the standard mode when i calibrated it. vivid is too hot and movie is too dark for me.
    adam - now you've got me thinking. i never realized it reset the settings when i switch picture modes...which i sometimes do when goofing off... [​IMG]
  4. Mike___Walker
    Jan 12, 2002
    29
    It doesn't seem to be resetting when I switch modes, so I'm going to use it. I figure I'll use the Movie mode for daytime & the Standard mode for night. The only problem I had using the Avia for Video was with the color chart. That part sucks [​IMG]
  5. Bill Catherall
    Bill Catherall Screenwriter
    Aug 1, 1997
    1,560
    My Sony has three picture modes too. For me, the settings don't change when I switch modes. I use "Standard" for watching TV and "Movie" for watching DVDs. Standard mode was calibrated with a composite video cable attached to the DVD player, Movie mode was calibrated with an S-video cable on the DVD player. I don't touch "Sports" mode (probably the same as your "Vivid" mode. It's still in the factory default "torch" settings. [​IMG]
