video cable question
Discussion in 'Archived Threads 2001-2004' started by John-Miles, Sep 27, 2002.
  1. John-Miles
    John-Miles Screenwriter
    Nov 29, 2001
    1,210
    I am planning to upgrade my DVD player soon and so i will need some component cables. I was lookign at some AR cables and i was thinking it would be cheaper to buy their regular RCA cables and just use those for component cables. would this give me the same effect as their packaged component cables? if so what is the reason for the difference ????
    more shielding or something? please explain [​IMG]
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    The same coax is used in both. A component cable set is simply 3 composite cables in a single bundle.
    However: the component cable bundle is usually less-messy than 3 individual wires. The component cable bundle has different color codes on each plug to avoid confusion (you will need to/should label your individual video cables). And the component cable bundle has all the 3 cables cut to the exact same length to avoid timing issues.
    IMHO: your video cable should be your most accurate/precise/highest-quality cable in your system. Dont cheapen out on this cable.
    The AR component cable has been praised for it's high quality at a budget price. To try and save a few bucks below this is a "penny-wise and pound-foolish". Remember the 10% rule: budget 10% of the electronics cost for the cable. Anything less than that is a bonus.
  3. John-Miles
    Nov 29, 2001
    1,210
    Yeah i suppose so.... and it is only a few dollars difference, but to be perfectly honest i think its foolish to spend several hundred dollars on some monster cables... AR it is i guess. thanks [​IMG]
  4. DanaA
    DanaA Screenwriter
    Nov 21, 2001
    1,843
    John,
    Please do me a favor and check out the link below to Rhino. They have three flavors of component cables and I switched to the ones linked below from AR's. It really made a significant difference in the picture's detail, depth, and color richness, at least in my perception. And, they don't cost much more than AR's. I think they might have a trial period in which you can return them if you don't like them. Here's your link
  5. BenK
    BenK Stunt Coordinator
    Aug 27, 2002
    205
    I tried one of Rhino's component cables and found it to be noticeably worse than my AR component cable. I was pretty surprised especially since it was just the performance series and not the pro or master series. I can say that Rhino's customer service was excellent though when I returned it.
  6. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    well that's puzzling, not that I'm a fan of Rhino, but puzzling. what was the nature of the problem? bad connection or something?
  7. Mark Rich
    Mark Rich Second Unit
    Oct 24, 2001
    457
    Hmmm...That is very surprising as they use nothing but broadcast cables (Belden 1694/1695)and connectors(Canare). My experience with Belden cables over AR is completely the oposite!
  8. DanaA
    DanaA Screenwriter
    Nov 21, 2001
    1,843
    Ben,
    I'm kind of surprised at your experiences with the Rhino Performance series component cables too. I'd have to speculate that perhaps they were damaged or something, because even my two daughters noticed a positive difference with mine when watching Monsters Inc and they didn't even know what I'd done. Sorry, it wasn't a better experience for you.
  9. Lee Petty
    Lee Petty Stunt Coordinator
    Jun 1, 2002
    204
    you might want to check into an AR Pro cable, as the component cable in that series is better than just the regular rca video cables. plus, it doesnt cost very much more than the regular performance series. even more bang for the buck if you ask me.
  10. BenK
    Aug 27, 2002
    205
    I've since tried the AR pro series component cable with very good results. I originally wanted the master series cable but they didnt have the right size. But I'm fine with the pro series...for now. I'm still curious as to the Rhino cable though. The only thing I can attribute to the lower performance is maybe it was faulty. I would still like to try a canare/canare component cable from Heartland cables or similar vendor to appease my curiosity. The wait and shipping/return shipping is more favorable than to Canada (Rhino).
