RichardJames
- Jul 12, 2004
Please help me understand what is going on here !!
Equipment:
HP Digital VP6120 DLP Projector
Pioneer DV-525 DVD Player
The problem I am having is this, when a watch certain movies I seem to be getting vertical lines through some parts of the picture. This is through component output.
When I watch the same as above through my laptop dvd player the picture quality is so much better. No vertical scan lines. VGA output.
I have a link below with a couple of digital photos of the problem.
svc035.bne034u.server-web.com/vga/index.html
I think it seems to happen on bright parts of the picture. With the picture in the above link you can see the fish has vertical lines.
I don't know why this is happening. My understanding is component is much, much better than VGA. So if that is the case why am I getting vertical scan lines ?
If it turns out you will always get a better picture through a pc because the resolution of a pc is higher, then why would you bother using a dvd player. Would it not be better to view movies via a pc dvd player ???
Could someone please explain what is going on
Richard
Equipment:
Richard
