Daren Welsh
- Jan 16, 2002
If you read my sig, you'll see that I've got a 65908. It's got a VGA input, but the manual insists that I can only get 640x480 through that connection. I've tried reading up on PowerStrip because I'd like to try upscaling my DVDs through a HTPC. My first question is if I have that VGA input on my Mits, can I just use a plain old VGA cable to connect my HTPC to the TV and use PowerStrip to get 1080i signal? Or, will I need to use some VGA->Component converter and connect that to my only 1080i input?
