Very strange issue using Samsung SIR-T151 HD receiver
Discussion in 'Playback Devices' started by Adrian D, May 6, 2005.
  1. Adrian D
    Adrian D Stunt Coordinator
    Jan 30, 2001
    66
    For HD, I use a Samsung SIR-T151 OTA receiver.
    If there is a loud sharp noise in the room, I seem to "lose" the signal for a moment. After a second, everything is ok.
    I use an outdoor antenna.
    Any ideas why this is happening?
  2. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    Wow, I've never heard of anything like that with my 151.
  3. John S
    John S Producer
    Nov 4, 2003
    5,460
    I'd try a slight reloactin or turning of the outside antenna. If for no other reason, I just can't see much else have impact on it.
    I mean, I get stuff like this from time to time, low power transimitions still here in denver, using an indoor powered antenna. Even an automobile going down the street can cause it at times.
    Best of luck with it.
  4. Tony Kwong
    Tony Kwong Supporting Actor
    Jun 20, 2002
    521
    For automobile maybe some of the signals you are recieving are reflected from the street/other houses. So when a car goes by something gets in the path of the signal.
  5. John S
    John S Producer
    Nov 4, 2003
    5,460
    Could be.. Sometimes if I cough.. Blip!!! [​IMG]
  6. Adrian D
    Jan 30, 2001
    66
    I have a rotator, which I have to use to get my locals.
    It happens on any channel (or antenna position).
    I can understand signal path disruption as has been described, but I can duplicate the problem at any time by simply yelling or slaming a book on a table.
  7. Phil A
    Phil A Producer
    Oct 1, 2000
    3,171
    38
    Central FL
    Phil
    Sounds like it could be a loose connection at the antenna terminal at either the wall or the unit, perhaps even inside the unit at or near the antenna terminal. Have you checked the tightness of all the connectors?
