Yep, you just need any sort of TV tuner, like that satellite receiver you mentioned. S-vid works fine, as with composite, or VGA (ie. the Viewsonic VB50), or any number of inputs.
The best way to view a FP is like a computer monitor. The computer (receiver w/built in tuner and DVD player) is the source of the signal. The monitor (FP) is projecting the source component's signal.
Once I realized that my RPTV was only being used as a monitor...plus, I have a dedicated room with the ability to control light..it became a no-brainer. I will never go back to a RPTV again, when I can have 106" of HD.
Ron
PS: I just realized it's my 1,000 post! Thanks to Ron and Parker for a forum to share the fun/passion of HT.
Ron, how much did you spend on your projector if you don't mind my asking? I am getting ready to buy a 3000 dollar Toshiba, but if there is a better option for around the same amount of money... I am guessing a good projector costs a lot more than 3 grand though.
I also can completely control the light in the room that I will use.
I bought a Cinema 13HD (Sanyo PLV60) LCD projector. Naitive 16x9 panels and HD compatable. THis cost 3,699. I bought the screen used for $400. Two projectors in your range that seem to be a hit at AVS forum are the Sharp M20X for 2,700 and the Panny AE100 for 1400 (from Japan) or 1,800 from a US retailer. Send me a PM with your phone number if you would like to talk in detail. I've spent the last couple of months researching....so it's fresh, but I am by no means an expert. One the thing I do know is that having a FP with 106" screen finally makes the room feel like a home theater.
Thanks guys. I thought that was the case, but I just wanted to make sure. I am probably going to buy the panasonic ae100 also. My goal is to have my system up and running before the Superbowl.
Does anyone know of any posts regarding ceiling mounting projectors, and alternatives to the $300 store bought units? Also, what about good sources to purchase ceiling mounts online, if I have to go that route?
There are a lot of easy ways to do a home made ceiling mount for the AE100 if you want to save money. Plenty of people used a swiveling Dremel D-vise and an aluminum plate (drilled for the foot holes).
Here's some info: DIY Piano HE3100 ceiling mount
