brian a
- Jan 29, 2000
I though I had a handle on the whole sat/sub crossover thing until I read this today on avs:
Anyway, back to the woofers. It happens that I'm in the middle of some sims designing a system with Scanspeak drivers with sorta similar (close enough) specs to the HiVi drivers in the Divas. Now, lots of speakers can be designed to play low using small drivers with skillful box design. But, if you want it low AND loud AND clean the laws of physics say you can't move enough air to get the job done with tiny drivers. So, what do the sims say? Anechoic response (no room gain), with a sealed enclosure, gives you a max of the following before the distortion gets really ugly:
Two 8" drivers: 102dB at 2 meters and 80Hz
Two 5.5" drivers: 94dB at 2 meters and 80Hz
One 6.5" driver: 90dB at 2 meters and 80Hz
So that's saying that with your crossover at 80Hz you need at least 2 8" drivers in your mains. That seems to go against a lot of what I had read. If this is the case, how could you ever justify setting a set of mains to large?
brianca.... (still learning before next speaker upgrade)
