MikeVM
Grip
- Sep 3, 2003
I just purchased a new NAD T752 to replace my aging Denon receiver. The main reason for this upgrade was to be able to enjoy the digital surround features of this receiver, and of course the NAD is a much more "musical" amp.
My DVD player is a Denon DVD 3000. Not progressive scan, but good enough for now. So I hooked up the coaxial digital output to the receiver, and all was good. I popped in a DVD and the sound was stunning.
Now the bad news. I popped in a regular CD (Stevie Ray Vaughan if you must know) and noticed that during playback the first 1/2 second of every track is cut off if you just let the CD play. To rule out the DVD player, I tried three other players, using both optical and coax, and they all do it. Other CDs are affected too. Then I tried setting up the input for the CD setting on the receiver, and it still does this.
I would guess that the receiver tries to acquire the type of encoding every time the CD switches tracks, and it takes a little time to acquire the signal type.
So I called my dealer, and they said "use analog connections". This is unacceptable. Not only does that negate the built-in crossover for my LFE sub, but the DACs in the DVD player sound like crap compared to the ones in the receiver.
For a 900 dollar receiver that is supposedly built around the "sound first" principle, I find it rather offensive that something as simple as playing CDs through a digital interconnect doesn't work correctly.
Has anyone run across this? What is the fix?
-Mike
-Mike
