Vertical compression by TV vs DVD player
Discussion in 'Beginners, General Questions' started by Alvin.G., Jul 14, 2004.
  1. Alvin.G.
    Alvin.G. Stunt Coordinator
    Oct 23, 2003
    64
    When watching anamorphic DVD's on a 4:3 TV, which is better at doing the vertical compression, the setting on the TV vs that one on the DVD player?
    If I use the TV setting (ie, set the DVD player to display for a 16:9 display and then set the TV to view anamorphic material), I have to switch to view nonanamorphic material on the DVD, namely the menus and special features. If I set the player to display for a 4:3 TV, it automatically compresses the 16:9 material and leaves the 4:3 stuff unaffected (ie, this is more convenient for me). But, convenience aside, which is going to give me the better picture. Thanks
    acg
  2. StephenHa
    StephenHa Second Unit
    Sep 28, 2003
    364
    all depends on the tv and player some players are better than some tv's and vice versa, which one looks better
  3. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    Depends what your TV is doing. What kind of TV do you have? If you're talking about a TV doing a raster squeeze, do that preferably.
    It is important that you keep your DVD player in 16:9 mode if possible, as this will maintain the full benefit of anamorphic transfers.
  4. Jeff Gatie
    Jeff Gatie Lead Actor
    Aug 19, 2002
    6,531
    15
    Actually, raster squeeze (16:9 mode) on the TV is always preferable to downconversion in the DVD player. The reason is raster sqeeze preserves the resolution of an anamorphic DVD; downconversion essentially "throws away" every 4th line. Some players are more sophisticated in their downconversion algorithms than others, but all are inferior to displaying the full 480 lines of vertical resolution.
  5. Alvin.G.
    Oct 23, 2003
    64
    I have a 27" Toshiba, and it does have a 16:9 mode. Do all dvd players use downconversion to modify a 16:9 image? I have a sony player.
  6. Jeff Gatie
    Aug 19, 2002
    6,531
    15
    When set to 4:3 mode, all DVD players use downconversion to convert an anamorphic DVD. They have to because if they did not, the image would not be displayed correctly; it would be stretched vertically. If you have a 16:9 mode on your TV, set your DVD player to 16:9 and use you tv's 16:9 mode for all anamorphic ("enhanced for 16:9") DVD's.
  7. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Simply set your DVD player's picture-setup menu to 16:9 and be done with it. If your Toshiba auto-detects a 16:9 signal and compresses the raster, fine. Or if you have to adjust the Toshiba's raster manually in the user menu, fine. Just leave the DVD player at 16:9 output and you're good to go.
  8. Alvin.G.
    Oct 23, 2003
    64
    Sounds great. I have to set the 16:9 mode manually, but its more of just a minor annoyance than anything else that I have to switch it back to view 4:3 material on the DVD.
    Thanks for the help.
    acg
