George W
- May 25, 2001
Hello all,
It's been awhile since I've been able to work on my speakers but I'm back at home for a bit and I'm finally ready to veneer my speakers. I may have asked this before but I have since forgotten so I need to know the common method for doing seamless veneer trimming on edges and corners. I would like to use the router for this task and I thought I could use a flush trim bit for this. I originally thought that I would lay down one side of veneer and then trim the edge with a flush trim bit. Then I'd lay down the next side and go back over the edge from the other side, resulting in a seamless edge. I mentioned it to my Dad though and he seemed to think that I would need to lay down both sides of veneer before I did any trimming, so the width of the veneer wouldn't get subtracted on one edge. He also mentioned that he used to use some sort of a 45 degree router bit when he used to lay laminate and it took and equal amount off of both veneer edges and looked relatively seemless. Anyway I hope that's not too confusing but I was looking for a refresher on how the pros like Eric Jones and Brian Bunge do their edging. Keep in mind that I have no round overs on my speakers so I won't need to do any full wraps, just 90's. Can I just pick up a flush trim bit or do I need a "laminate" trimming bit or is something else advisable. At this point in the game I'd like to stear clear of any bits over $20 as the money is running dry. Also, What is the normal orientation of veneer on the top of the speaker; is it grain running towards the sides to match the sides or is it grain running towards the front/back to match the front? Lastly, after the veneer is glued and trimmed I plan on finishing it with brush on lacquer. I had a lengthy discussion with some helpful individuals on HTT a while back and someone mentioned using a laquer based sealer before applying the actual lacquer. I can't find that discussion now with the search function so If anyone knows the specifics of such a product I would appreciate more details. Thanks for all the help.
-George
-George
