Veneer for beginners
Discussion in 'Home Theater Projects' started by Rich-R, Feb 5, 2004.
  1. Rich-R
    Rich-R Extra
    Oct 7, 2003
    19
    I am planning on finishing by sub with a cherry veneer but I am not sure what kind of veneer is easiest to work with but still look good. It will just be flat and on the sides. The corners will be solid maple along with a maple "table top." Paper backed? Non backed? Help. rich
  2. Joey Skinner
    Joey Skinner Second Unit
    Sep 12, 2003
    339
    I used paper backed veneer and contact cement for my speakers and sub. I was a little intimidated at first having never veneered before but it turned out great. Doing just the flat sides of a sub should be easy. Do a search in this forum for "Brian Bunge veneer question" and you'll find good tips.
  3. Pete Mazz
    Pete Mazz Supporting Actor
    May 17, 2000
    761
    The absolute easiest is either Peel & Stick backing (think contact paper application) or the iron-on hot melt backing. You can find them available online at Tape Ease for the P&S or Tape Ease for the hot melt.
    Pete
  4. Dave Poehlman
    Dave Poehlman Producer
    Mar 8, 2000
    3,813
    I had trouble with the iron-on stuff sticking on the edges... I'll vote for the paper-backed w/contact adhesive. I used the water-based adhesive. I know some here detest the H2O based stuff, but I've never had trouble with it.
  5. Hank Frankenberg
    Hank Frankenberg Cinematographer
    Oct 13, 1998
    2,573
    I used peel-and-stick once, a few years ago, as it was my first attempt at veneering. If you go that way for ease and minimum intimidation, be sure your MDF surface is very clean. Use a tack rag and then wipe with solvent - mineral spirits or alcohol and let dry for a while. For your next project (and there WILL be a next [​IMG]), you can move on to 10-mil paper-backed veneer. That's where you'll get your largest variety and best quality veneer.
  6. Bob K
    Bob K Stunt Coordinator
    Dec 29, 2003
    94
