Velodyne VLF1012
Discussion in 'Archived Threads 2001-2004' started by Kattada, Mar 30, 2002.
  1. Kattada
    Kattada Auditioning
    Mar 26, 2002
    Can any one advise me ? Which sub to go for,
    Velodyne CHT12 or VLF1012. Both are priced at $ 499.00
  2. steve nn
    steve nn Cinematographer
    Jan 12, 2002
    2,418
    I know this does not answer your question but is a Vel-ct.150 out of the question.It is big >the way I like my sub< but it has the same driver as the cht.150.300 rms 750 peak.You can get the ct.150 for $450-$550.The grill on the front of the cht. is the only dif.If you have any Velodyne dealers in your area they might have one of last years models they would sell you or a demo for even less.This was the case with me.There has been some confusion on the specs of the ct.150.I called Vel and confirmed the 300 rms 750 peak on the ct.150.I don't know what your bass needs are but the ct.150 does one good job.I do know there are better subs out there,but if its vel. that you want, I would consider this rout if all of the factors line up.I really enjoy mine.The 18" vel or twin svs will be the end of the bass road with me and the ct.150 does a good job of holding me over untill then. Good luck!
