Velodyne HGS15 II making a "POPPING" noise
Discussion in 'Speakers' started by Kevin*Harley, Oct 11, 2003.
  1. Kevin*Harley
    Kevin*Harley Stunt Coordinator
    Jan 15, 2003
    137
    My Velodyne HGS15 II starting making a continuous popping noise when it turned last night. Has worked perfectly up to that point.
    It started happening for no apparent reason. Sat down to listen music and the minute the sub turned on the popping started.
    The sub is less than 9 months old and under warranty so I have no problem taking it back if something is blown. However if there is anything I can do please let me know. I would rather not have to lug a 90lb. box in and out of my home again.
    Thanks in advance.
  2. Arthur S
    Arthur S Cinematographer
    Jul 2, 1999
    2,568
    Kevin
    Have you called Velodyne yet? I know it is hard to wait over the weekend to start to get to the bottom of a problem. Keep your fingers crossed, maybe they can help you without having to ship it back.
    Let us know how you make out.
    Artie
  3. Thomas Willard
    Thomas Willard Stunt Coordinator
    Sep 15, 2003
    97
    Popping sound can be a symptom of the speaker surround which attaches the cone to the basket (metal frame of the speaker)being torn. The popping sound results when the speaker voice coil rubs against the tube in which the voice coil travels. Try listening at very low volume and see if you hear the popping. If you only hear it at higher volume levels then, I would guess either the foam surround is torn or for some other reason the voice coil is loose.
  4. Kevin*Harley
    Jan 15, 2003
    137
    I called Velodyne but doesn't look like they have cust. service over the weekend.
    The popping sound is there at any volume. The instant the sub turns on it starts. I pulled the grill off this morning and visually the cone looks fine. If I stabalize the cone with my finger the popping stops. However, the instant the sub receives a signal and the cone moves the popping starts again. Even if I tap the outside of the sub with my hand, the vibration will trigger the popping.
    What are your thoughts?
  5. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    Kevin,
    It definitely sounds like a defective driver. It could be that the voice coil is out of alignment and is causing the popping sound. Try turning the sub off completely and lightly push in on the center of the driver. If you hear a rubbing or scratching sound then the driver is damaged.
  6. Kevin*Harley
    Jan 15, 2003
    137
    Brian, Thanks for the reply.
    I just did what you suggested but didn't hear any scratching noise. However, the cone is very taunt when the sub is off so the pressure I applied and movement was very little (I didn't want to dent the cone if I have to send it back).
    On a side not:
    This sub has impressed the hell out of me each and every time I hear it and although it [​IMG] me that it's defective I am more [​IMG] that my HT will be subless. It's amazing how much a sub adds to the movie/music experience.
  7. Rudi B
    Rudi B Stunt Coordinator
    Jul 18, 2002
    143
    I'd say that most probably the active servo mechanism went haywire, if the driver itself is okay...
  8. James W. Johnson
    James W. Johnson Screenwriter
    May 26, 2001
    1,055
    Dont worry about it, just call Velodyne Tech support on Monday , they will take care of you. Velodyne has excellent customer service.
  9. Kevin*Harley
    Jan 15, 2003
    137
    Spoke to Velodyne today. After describing the problem they said it’s my amp. Unscrew the amp, send it to them and I should have a new one in 7-10 days.
    Very helpful Customer Service with no hassle.
  10. Erik_C
    Erik_C Stunt Coordinator
    Jun 15, 2000
    186
    My Velodyne 18" just had a similar problem. Turns out the amp needed fixing. Velodyne has great customer service, and my experience having the amp repaired was painless and done right the first time.
    -Erik
