Velodyne HGS-18 assessment
Discussion in 'Archived Threads 2001-2004' started by John H, Sep 24, 2001.
  1. John H
    John H Second Unit
    Nov 27, 1998
    472
    I have been using a pair of Definitive Technology PF18TL subwoofers in my system for a few years now. I also have been using an Audio Control PCA III on the signal. The PCA generates subharmonics 1 octave below the original signal and mixes them in. It uses a sampling range of 70-35 Hz. So basically it is adding 35-17½ Hz subharmonics.
    I replaced the PF18's with a pair of HGS-18's on Friday. Over the weekend I did a little tweaking and demoed the subs in my system.
    The Velodynes outperform the Def Techs in the low end by a fairly good margin. They extend much deeper with greater output. The bass is also tighter and more controled.
    I use my subwoofers in conjunction with a pair of Buttkicker tactile transducers. I am finally pleased with the low end in my system.
    TV suggested considering 4 Ultras as an alternative. Unfortunately due to space that was not an option.
    Bedroom Based Theater
    ...looking through a glass onion
  2. Chad Isaacs
    Chad Isaacs Supporting Actor
    Feb 20, 2000
    757
  3. John H
    John H Second Unit
    Nov 27, 1998
    472
  4. Hubert
    Hubert Second Unit
    Mar 9, 2001
    424
    Yep! The big Velodynes are awesome. However, you're comparing apples to oranges. The HGS-18 costs a lot more than the PF18TL subs do. That means a lot more high end components went into the HGS-18. The PF18TL is an attempt and at large and powerful, yet inexpensive sub. At least inexpensive given it's power and driver size. So yes, the HGS-18 is a lot better in the low end. I love mine.
    [Edited last by Hubert on September 25, 2001 at 08:28 AM]
  5. Tom Vodhanel
    Tom Vodhanel Cinematographer
    Sep 4, 1998
    2,224
    11
    610
    Excellent to hear John,
    I remember thinking...probably YEARS ago now(when we first bumped into one another)...you'd eventually end up with dual 18" servos [​IMG]
    I see some Buttkicker2s,and a pair of HGS10/12s(for your surrounds) in your future...
    TV
  6. John H
    John H Second Unit
    Nov 27, 1998
    472
  7. Jay Mitchosky
    Jay Mitchosky Producer
    Sep 6, 1998
    3,729
    John H
    Could you please edit your signature? It has an usual amount of blank space at the bottom.
    Many thanks.
    --Jay
    "No one can hear when you're screaming in digital."
    My Home Theatre Pictures...
    "You're no messiah. You're, you're a movie of the week. You're a ... t-shirt, at best."
  8. Michael Roderiques
    Michael Roderiques Stunt Coordinator
    Aug 25, 1999
    174
    John, Good to hear that you are happy with the HGS-18's.
    How do you have them set up? Left/Right or mono?
  9. John H
    John H Second Unit
    Nov 27, 1998
    472
  10. Will
    Will Guest
  11. PomingF
    PomingF Second Unit
    Mar 4, 2000
    343
    John, if that matters Stereophile just came out with their latest recommended equipment list and now only the $4k Revel is considered class A SW together with the big Velo. [​IMG] Have fun.
    PF
  12. Bhagi Katbamna
    Bhagi Katbamna Supporting Actor
    Jun 1, 2000
    870
    I would take the SGHT reviews of subwoofers with a grain of salt since they don't actually do measurements. That being said, the Velodyne is an awesome subwoofer.
