Matt Meyer
- Mar 29, 2002
Velodyne introduced there monster sub the "Signature 1812" at Cedia this weekend. With 2500 watts and a 18" woofer for 50hz and below and a 12" woofer for above 50hz. And so you get your 15k worth it comes with an onboard computer, you take the included microphone plug it in the back of the sub hook the sub to a monitor and it plays it own test tones and shows you the room curve in real time. Then if you need to flatten the curve it has a 5 band parametric eq also. The thing was a monster it has all the tools to raise the bar higher than it has ever been.
Matt
Matt
