JasonMorton
Grip
- Oct 20, 2002
Hi Guys,
I finally took the plunge and purchased a subwoofer yesterday. I went with the Velodyne CHT-15 as I got a great deal on it from the local stereo shop. I'm running it through an older Pioneer receiver model VSXD606S. I've wondering on some of the receiver settings and I cannot find the manual. My room is around 3500 cubic feet and I am about 10-12 feet from the TV and speakers. Any advice I could get from you guys would be greatly appreciated as Pioneer has been about as helpful as a kick in the head. Here I go:
1) Should I use the the receiver's crossover, the subs or both? If so, where would be a good place to start?
2) I have a few settings on the receiver that I am not sure where to set as I am not very familiar with things:
a) DRC On/Off?
b) Lowcut On/Off?
c) LFE ATT Off/0db/10db?
d) Xover 100/150/200db?
Does anyone know what some of these settings might be or possibly where I should set them at?
3)I have the receivers sub volume set at 3db and the sub volume at 3. Is is beneficial to turn up the sub out to like 5 or 7db rather than turning up the sub gain?
I know I'm getting long here but one last question. I tried to test a CD last night with a good bass track and found that I had to really turn up the gain on the sub to get bass whereas when I as testing the bass with ATOC the bass was more pronounced at lower volumes. Is this normal?
Once again, forgive all the stupid newbie questions and thanks in advance for any advice.
Jason
a) DRC On/Off?
b) Lowcut On/Off?
Jason
