Velodyne CHT-10 or the bigger CHT-12?
Discussion in 'Speakers & Subwoofers' started by DarrenB, Apr 22, 2004.
  1. DarrenB
    DarrenB Extra
    Apr 5, 2004
    15
    I've recently started upgrading my HT and am needing a sub for under $500. The CHT-10 at $229 with free shipping seems like a dang good deal but the CHT-12 for $299 seems equally good. My room is 15 x 30 and is all tile with some area rugs. Any suggestions as to which one to buy would be appreciated.
    My current components:
    Onkyo TX-NR801
    Klipsh KG 3.5 Mains
  2. DarrenB
    DarrenB Extra
    Apr 5, 2004
    15
    Come on guys I know there is someone with some info on these Velodyne subs....
  3. Alex_P
    Alex_P Stunt Coordinator
    Nov 3, 2003
    133
    Darren, I auditioned both of those subs... It doesn't seem like it can keep up w/ low freqs... I said go for the Rava from Adire[​IMG] for $400...
    Alex,
  4. TimMc
    TimMc Stunt Coordinator
    Dec 30, 2002
    220
    Darren - they're not bad subs at all, but your satisfaction with them could depend a lot on the room you're in. Smaller room - OK. Anything larger will probably be really pushing it (but that also depends on your criteria).
    With up to $500 for a budget you have lots of great options. You could also look at that Adire, and there are a couple of HSU options, too (STF2 and maybe even VTF2). Then there's the Dayton Vance Dickason 10" from Parts Express that's $350 shipped - check that out as an option and still have money for more program material. The list goes on...
    Bottom line is probably the same - get the best you can afford now and save yourself some sooner-than-later upgradeitis cost.
