My bookshelf speaker stands came with little Velcro dots that would help keep the speakers from being knocked off. If I install these dots, what, if any, effect would it have on the sound?
I currently ise velcro to secure my speakers to their stands. The velcro does 2 things... first, it secures the speaker so it does not slide off the stand. Secondly, it acts like an "insulator" so the speaker is isolated from the stand otherwise vibrations could ensue.
Just thought I would tell you I used 2 sided tape to secure my last speakers to the stands. I was always worried that someone would knock them off. Even with the 2 sided tape I worried. I shouldn't when it was time for them to come off I couldn't pull them off. I had to pry them off. No damage was done luckily. That stufff really holds.
Just a tip if anyone uses two sided tape and wants to remove it: you'll want to use a solvent used in installing grips on golf clubs. One particular brand, made by Brampton, is non-toxic, has little smell and would be safest to use. In the case of a speaker held down by double sided tape, I'd use a butter knife or something similar to pry the tape a tiny bit and squirt some of the solvent at it. Wait a few seconds and you'll probably notice the tape loses its stickiness. Keep prying and squirting the solvent.
Probably, though you can also mail order it. Two companies I use are Golfsmith and Golfworks. Some retailers may carry it but you'd be more likely to find it at a component supply store (they'll sell clubheads, shafts, grips, etc).
If there's a "non-golf" equivalent of this solvent, I don't know what it'd be.
Instead of using two sided tape or velcro, another option is blu-tak or a similar product. It's probably more secure than velcro (your speakers won't budge), and easier to remove from speaker and stand than two sided tape (it peels off nicely).
I third the blu-tak. you can get it at staples or office max also... I use it and it takes a few minutes of gently working my speaker back and forth until if finally lets go. Its good stuff. Your speakers won't go anywhere.
I'll 4TH blutak..that shit rocks! I use it on all my speakers...and have actually hid one of my runs of speaker wire under the fireplace brick...it held perfectly!
