Vector Pro Plus Universal Projector Mount
Discussion in 'Hardware Classifieds' started by Ron Boster, Aug 17, 2004.
  1. Ron Boster
    Ron Boster Screenwriter
    Jan 10, 1999
    1,145
    Peerless PJF 45 - Vector Pro Plus Universal Projector Mount
    The Vector Pro Plus Universal Mount is designed to surround and clamp the projector. The ball & socket design offers complete, integrated security from the projector to the ceiling and multi-directional positioning for proper lens alignment.
    Adjustment: One security screw adjusts yaw (360 degree), roll (+/-15 degree), & pitch (+/-15 degrees)
    It's silver in color. Width ranges from 10.75"-18.75"
    Height ranges from 5.5" to 10" It weights 9 lbs.
    I bought this two months ago as a temp solution until Chief came out with a mount for a newly released projector. I will sell for $100 + $10 shipping. I have all the associated directions and parts.
    Ron Boster
  2. HeatherM
    HeatherM Stunt Coordinator
    Jul 28, 2004
    89
    sent email/pm
  3. Ron Boster
    Jan 10, 1999
    1,145
    For those interested in whether the mount will work for their projector. The projector's height needs to be between 5 inches and 10 inches. The width of the projector needs to be between 10.75 inches and 18.75 inches. The length of the projector isn't as important.
  4. Ron Boster
    Jan 10, 1999
    1,145
    To sweeten the pot, I'll throw in the matching extention column coupler that allows for cord management (cords run inside the extension column, through the hole in the coupler then out to the projector). The coupler connects the column and the mount. The cost was $35. It's free to you with the purchase of the mount, plus free shipping. So total cost for the mount and coupler from Peerless is $100 shipped to your door.
    Ron
  5. Ron Boster
    Jan 10, 1999
    1,145
    $90 shipped. Paid $200 just a couple of months ago. My loss your gain
  6. todbnla
    todbnla Screenwriter
    Oct 17, 1999
    1,514
    39466
    Todd
    So this is basically a box that the P/J sits in per say...? Appears to be multi fit in most cases
    This it?
    [​IMG]
    Free Bump!
  7. Ron Boster
    Jan 10, 1999
    1,145
    Yes, Todd that is it. Thanks for the bump and pic
