James Edward
- May 1, 2000
Just curious- I have been using the good old VE original for years, and recently picked up the 16:9 DVE.
On my set(Tosh 57HX81), the brightness and color settings calibrated 2 higher in each case, brightness going to 53 from 51, and color going from 47 to 49.
Sharpness also seemed to calibrate higher, from a setting of 39 to 42.
I thought perhaps the settings were different due to drift over time, but I popped in the original VE and sure enough, the calibrations were different. Problem is, I'm not sure which picture settings I prefer...
Just curious as to whether others have also experienced any difference between the two versions also.
