VCR recommendations: just for dumping TiVo recordings?
Discussion in 'Archived Threads 2001-2004' started by Ernest Aguayo, Mar 6, 2002.
  1. Ernest Aguayo
    Ernest Aguayo Stunt Coordinator
    Apr 5, 2000
    105
    Hey folks...
    I tried doing a search on VCR recommendations, but I couldn't find what I was specifically looking for in all those threads, so:
    Anyone have a recommendation for a relatively inexpensive VCR that I could use just for archiving/occasionally playing back TiVo recordings? I never rent/buy videos, I use a VCR mainly to make tapes of TiVo recordings for TiVo-less friends.
    I am looking to spend around $100, is this possible? Just want something basic like stereo and good audio/video. I don't care about remote/timer/menus, etc.
    Thanks for the help.
    Ernest
  2. Bill Will
    Bill Will Screenwriter
    Dec 26, 2001
    1,282
    For what it's worth from Consumer Reports:
    VHS MODELS SP-VERY GOOD EP-GOOD (This was the best rating)
    Sony SLV-N71 $130
    Philips VR674CAT $100
    Sony SLV-N51 $100
    Hitachi VT-FX665A $80
    Philips VR621CAT $80
    Myself I would buy one of the Sony models. If you really want to go cheap I would buy the Symphonic SL260B $60 which CR said "If you use your vcr mostly for playing pre-recorded tapes, you can get a good performer with fewer features for even less. The Symphonic $60 & GE VG4250, $70,are two good examples.
    What I've found is that the cheaper ones don't record that well because of the tunner's in them, but I would think that if your recording from your TIVO that should not make any difference. If I was you I would try the Symphonic vcr first & if your not happy with the picture quality take it back (make sure you can exchange it first) and then go with a Sony.
    Hope this helps you out. Oh Symphonic is now the worlds largest maker of VCR's. In fact they are making a lot of the cheaper priced vcr's for Philips, Panasonic & etc.
  3. Ernest Aguayo
    Apr 5, 2000
    105
    Bill, that's some great info there.
    Thanks!
  4. Bill Will
    Dec 26, 2001
    1,282
    Ernest, The Sony model SLVN51 has been replaced by the "NEW" SLVN55 & Circuit City has it advertised for $89.99 this week I know that WAL-MART, K-MART, SEARS & BEST BUY also have the Sony & they will match Circuit City's price if one isn't close to you. Again, I would give one of the cheaper HI-FI VCR's a try first, who knows one of them might work out OK for you. [​IMG] GOOD LUCK!
  5. Ernest Aguayo
    Apr 5, 2000
    105
    cool! thanks again, Bill!
