VCR+ Question..Does tape get marked..
Discussion in 'Archived Threads 2001-2004' started by Richard_s, Mar 1, 2002.
  1. Richard_s
    Richard_s Second Unit
    Nov 25, 2000
    267
    From the posts many of you helped me in so far it looks like the JVC recorders may be my best bet. The question I have is this:
    With VHS + (or maybe some other feature) if I record a few shows on the same tape does the recorder mark the beginning of each in any way so it is easier to find or do I have to just scan (trial and error) to find the beginning of each program.
    Thanks all
  2. LeungNing Chu
    LeungNing Chu Auditioning
    Nov 16, 2001
    4
    My JVC 7600 will automatically mark an index code at each recording. Use the 'Index search' function to access each recording.
    L. N. Chu
  3. Richard_s
    Nov 25, 2000
    267
    LeungNing
    Thank you just what I wanted to know. I will check the manuals for the model JVC units I am looking at to make sure it has the index search.
  4. Ray Kammer
    Ray Kammer Agent
    Feb 6, 2002
    33
    Just in case you haven't made a decision yet, I just took delivery of my JVC JR-S7800U from Crutchfield on Friday. I really like it so far and it does have the index search. Got it from their Scratch 'n Dent sale for only $169.00. It came in perfect and works great. Good luck.
  5. Richard_s
    Nov 25, 2000
    267
    The JVC is my top choice right now based on what everyone here tells me about it.
    Does the scratch and dent stuff from crutchfield carry a full warranty and 30 day return policy?
    Also did the JVC 7800 that you purchased come with the IR mouse?
    Thanks again. About ready to order [​IMG]
  6. Ray Kammer
    Ray Kammer Agent
    Feb 6, 2002
    33
    Richard, If you mean the IR devise that controls the cable box for VCR+, yes, mine came with it. The 30 day return policy applies to the scratch 'n dent stuff but the manufacturer's warranty does not. Crutchfield honors the manuf. warranty themselves for whatever the original warranty period is. They've been in business for 30+ years and that was good enough for me. Good luck.
  7. Richard_s
    Nov 25, 2000
    267
    Ray:
    Thanks that is exactly what I needed to know.
    Appreciate the information
    Richard
